hi,
I have a terminal with prints now, but it seems not continuing it stop at fail. Pls check the image below
could we disable the gate testing? during initialization?
hi,
It seems the gate driver of the mosfet has issue on my board that's why it's failing the test. Added a switch to bypass the mosfet. Can any one check the driver, if there is a fix, pls let me know.
Dear Suvasis,
for software to the RDDRONE-BMS772 please refer to this link. Have you used software from there?
With Best Regards,
Jozef
