I am running MCUXpresso IDE v11.6.0 [Build 8187] [2022-07-13] on my Windows 10 machine. The MCU we are using is the LPC4076.
I am using a Pre-Build Step to copy either a DEBUG version of the memory.ldt or a RELEASE version of memory.ldt to ./linkscripts/memory.ldt so that I can make room for a bootloader in the RELEASE version.
The problem I am seeing is that the Pre-Build Step does not happen until AFTER the build is complete.
This requires me to build twice every time I switch my Active Build configuration back and forth and definitely does not work if I select the “Build All” option.
Do you know of any workaround for this issue?
Alice,
What good are Pre-Build steps if they don't happen Pre-Build?
Doug
Hello @DougHoyt
How about have a look at:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=501065
Alice
