Power management, Freescale 13.1v or 12.6
tyler3
We are using the iMX535 in a device that uses a lithium ion battery pack that the battery manufacturer recommends not be charged above 12.6V MAX.
The manufacturer of our device is recommending a power management circuit suggested by Freescale, which includes a 13.1V charging voltage. We are running Android 2.3.4.
Would you please confirm that a 13.1V charging voltage is correct?
I have attached spec sheets for the battery pack and the protection circuit.
Please let me know if any additional information is needed.
Thank you.
