By default, using the open (default) settings should work. (CHx_SETx = OPEN)
But for the first build, I would suggest to still have the pull up and pull down resistor footprints in place on the setting pins, just in case the OPEN settings are not optimum.
If this your new design you can consider about PTN36043A part, it will be more USB-C compliant.
The difference between the PTN36043 and PTN36043A is that
The reason is to be comply with Type-C’s safe state requirement.
