PTN3460_1024*768
PTN3460_1024*768
Jhon_Wan_V
we are using the PTN3460 F6 chip on our custom board to do displayport to LVDS conversion. Our flat panel support only 1024x768 72Mhz resolution, but we can`t change default resolution 1920x1080 stored in PTN3460. Could you please provide a link to the EDID utility to modify EDID and change default resolution permanently?
Jhon_Wan_V
Hello David,
Can you provide "PTN3460 FoA EDID Updater tool"?
Jhon
diazmarin09
Hello Jhon_Wan_V,
Sure, please review your email as before.
I hope this material will be useful for you.
David
diazmarin09
Hello Jhon_Wan_V,
I hope all is great with you. Thank you for using the NXP communities.
Do you mean the DPCD Tool?
If that is the case, please review the email that I sent you. You may find the tool requested.
I hope this information helps.
David
