PTN3360D HDMI Level-shifter
Showing results forย
Search instead forย
Did you mean:ย
kevinkrause
We are considering the use of a PTN3360D on our COM Ex carrier board. For ease of layout it would be useful to swap the +/- sense of all signal inputs and outputs. As this I.C. is a transparent(-ish) level-shifter using AC-coupling, we don't think this would be an issue. I welcome your comments.
gert_van_schie
Hello Kevin,
Did you implemented this swap, with what results?
Kind regards,
Gert
TomasVaverka
Hi Kevin,
In theory swap the +/- sense of all signal inputs and outputs should be OK, though it has never been tested. Have you considered mount the IC on the back side of the PCB?
Tomas
