We are having issues using the PTN3355 chip for converting DisplayPort to VGA. Everything works fine in windows using the chip. But when plugged in the Nvidia GPU we can't see the boot or bios screen. We have verified our layout with NXP but still unable to resolve the issue. We are leaning towards it being a chip firmware issue but haven't been able to get a response from NXP on how to update the chip firmware. Does anyone know where I can get the latest firmware and how to flash it. Some more information is listed below.
Thanks again for all your help with this and hopefully we can get this issue resolved.
There is no difference between FW F2 and F4, the only change is that FW F2 uses DP compliant mode as default setting but FW F4 uses DP non- compliant mode as default setting.
Could the non-compliant mode be why the bios isn't visible to a Nvidia GPU during boot? Do you know what the "X1" part of the firmware version means? Guessing just a Rev number?
