Hi All, I am using PN7462AU Eval kit for development with the "PN7462AU_ex_phExCcid" example & Smart cards. In which I have enabled the usb suspend mode to sink properly with system events(sleep, restart & shutdown) accordingly. But the issue is that it unable to detected available smart card, after system wake from suspend mode or restart(Power On) conditions, it required tap same available card once again. Even sometime it makes the PN7462AU restart automatically. Can you please let know solution for above issue. Looking forward for the possible solutions. Thanks & Regards Manva
