is there any possibility to read the FW version of the PN7160?
The only way i found is using NFC Testfactory APP and the log files
chris
Hello @chris123
Hope you are doing well.
Taking a look at the PN7160 NFC controller User Manual, Chapter 8 Initialization and operation configuration, FW_Build_Number should be contained in the NCI_PROPRIETARY_ACT_RSP parameters sent from the NFC Controller to the Device Host in response to an NCI_PROPRIETARY_ACT_CMD sent from DH to NFCC.
You can find more information on how to enable NCI communication traces in the PN7160 frequently asked questions, Section 19.1 How to enable logging.
Eduardo.
