The datasheet for the PCA9500BS appears to have a mistake on the pin-out diagram. There are two A2 pins and no A0 pin. The pin-out table is probably correct, but could you please confirm these pin numbers for me?
Thank you,
Richard
Hi Richard,
Thanks for pointing this out. Yes, pin 15 should be A0 in Figure 4. We will correct it soon in the next datasheet revision.
Tomas
never-displayed
