Hy, I'm struggling to control dot pixel display with 8578 and 2 8579s with no success.
Does anyone have i2c lybrary for the cheapset or any codes I could use for example.
I know the subadrresses for 8579s and that the display uses 1:8 MUX. I managed to use set mode commands and inverse video mode.
Thank you
Hi Aljosa,
unfortunately we do not have an example code or library for the mentioned LCD drivers. I apologize for inconvenience.
With Best Regards,
Jozef
