NXP level translating and I2C Bus repeater to replace TCA9509(TI)
1,332件の閲覧回数
Boler
Hi Team,
We are currently searching for alternative solution for TI's level translator TCA9509, can you help to advise which NXP chip can be the best option?
Thanks.
Boler
1,310件の閲覧回数
guoweisun
HI Boler
Connect the EN pin to VCCA via a 10k resistor should be OK.
Thanks!
4 返答(返信)
1,319件の閲覧回数
guoweisun
HI Boler
Please see below picture circled parts for replace TI part!
1,312件の閲覧回数
Boler
Hi Guowei,
Thanks a lot for your quick update.
PCA9509 should be the best option for our application.
By the way,  can you help to advise if any design consideration for the EN pin of PCA9509?
Can I just connect the EN pin to VCCA via a 10k resistor?
Or it also can be connected to VCCB?
Boler
1,311件の閲覧回数
guoweisun
HI Boler
Thanks!
1,308件の閲覧回数
Boler
Hi Guowei,
Got it, thank you.
