We are planning to apply NFC Reader IC PN7150 to other vendor's MCU instead of NXPs'
OS is RTOS.
Do we have to use a specific MCU in order to communicate between PN7150 and MCU through NCI protocol?
or Is it possible to integrate NXP-NCI to other vendor's MCU through SW porting?
I wonder if NXP_NCI can be implemented to other vendor's MCU as well regardless NXP products.
Thank you,
Andy
Solved! Go to Solution.
Yes. the application is OK. But The porting to other MCUs is not supported by NXP. Fortunately, you can refer to AN11990 and to the software examples available for our MCUs in the software examples which you can take as reference for your project
URL:https://www.nxp.com/docs/en/application-note/AN11990.pdf.
Have a nice day.
Have a nice day.
Dear fangfang,
Thanks for your prompt reply and explanation.
Thank you,
Andy
