NTM88 impadance matching
Pranav_Tonape
Hi NXP,
can anyone have a document for impedance matching guidelines for NTM88?
diazmarin09
Hello Pranav_Tonape,
I hope all is great with you. Thank you for using the NXP communities.
You may find the following post useful:
https://community.nxp.com/t5/Sensors/NTM88-433MHz-RF-output-impedance-matching-circuit/td-p/1394205
I hope this information helps.
David
Pranav_Tonape
hi David ,
thanks for your support,
for my TPMS application i am using an PCB trace antenna . i need help for antenna tunning from NXP team. actually we are facing packet missing and or garbage data receiving at receiver end, from hardware side i am tunning the TPMS antenna @ 50 Ohm on bench level . from software side we are sending data with 8 dB power also software side we increases the data packet and do the randomization packet sending but still we are facing. the TPMS are fitted on rim outside the tire.
need NXP help to resolved this issue
thanks and regards ,
Pranav Tonape
