NTB0102 - Please review the design
Search instead for
kiranashok
Dear Team,
Please find the attached snapshot. Kindly review the design and let me know your comments.
JozefKozon
Dear Kiran M,
please refer to Figure 9. in the datasheet. Your design is almost same, except that you have pull-down resistors on the B side pins. The pull-down resistors are not required by the NTB0102 and will increase the current consumption on the VCC(B). Are the pull-down resistors required by your IC on the B side?
With Best Regards,
Jozef
