NHS3152 Sleep and deep sleep Power savings
Search instead for
The NHS3152 IC has a sleep and deep sleep power savings modes. But no description as the reduction in power when these modes are enabled. Any guidance?
Hello @bmeyer ,
There is no detailed documentation on these power modes, the power gain compared to deep-power down is limited.
The difference between sleep and deep-sleep is only the handling of the EEPROM.
The power gain is dependent on the Sysclk frequency, as can be seen below in a graph of a typical application.
More power can be conserved by slowing down the Sysclk.
There is a slight increase of the Idd current (up to +12uA) when the Vdd voltage drops below 2.2V.
Hope that helps,
Kan
Hello Kan:
Thanks for the guidance. However, this doc still only details current consumption during active and deep power down. Doesn't mention current consumption during sleep and deep sleep.
Hello @bmeyer ,
Hope that helps,
Kan
Hello @bmeyer ,
If you have download the SDK package for NHS3152, you may find the doc on this topic, please kindly refer to the following for details.
Hope that helps,
Kan
