Hello All:
On the NHS3152 I2D converter, documentation states a minimum pulse period of 2uS for a 2.5uA input. However, the "NativeToPicoAmpere" assume a minimum pulse period of 4uS. Which is correct? Is there a settling which limits the minimum period to 4uS?
Hi @bmeyer ,
Which documentation are you referring to ? Would you please specify? Thanks for your patience!
Kan
