NFC Reader IC PN7150 can be a role of NFC Tag?
andy_kim
PN7150 is a NFC Reader IC.
I wonder if PN7150 can be a role of NFC Tag?
It not, are there NFC IC that could use Reader and Tag as well?
Thank you.
Andy
danielchen
Hi @andy_kim
Yes, in tag emulation mode, this allows both reading and writing of NDEF message by reader.  it simulates the function of a NFC Tag.
We have example for the tag emulation mode. please read section 5.2.3
https://www.nxp.com.cn/docs/en/application-note/AN11697.pdf
please note that PN7150 is not recommended for new designs. The replacement for this product is the PN7160.  please refer to below link for more details.
https://www.nxp.com/products/rfid-nfc/nfc-hf/nfc-readers/high-performance-nfc-controller-with-integr...
danielchen
Hi @andy_kim :
Yes, PN7150 can work at tag emulation mode. This mode allows emulating an NFC tag (NFC Forum T4T) to share data to a remote NFC reader (e.g. an NFC phone).
andy_kim
Dear Daniel,
Thank you for your prompt reply.
You mean the NFC Forum T4T on Card Emulation Mode of PN7150 for NFC Tag role?
Andy
danielchen
Hi @andy_kim
will_han
Hi @danielchen :
        I am looking for the way of  PN7150 as a tag.
        The development platform is Arduino. And The library Elecgtroniccats is used .But i can not find a way to use PN7150 as a tag.
       https://www.nxp.com.cn/docs/en/application-note/AN11697.pdf is for Linux !But is there any way of C or Arduino demo?
danielchen
Hi @andy_kim
Please refer to AN11990
https://www.nxp.com.cn/docs/en/application-note/AN11990.pdf
will_han
Hi @danielchen   :
      Thanks very much!
    I studied the code and found that the NDEF_MESSAGE was given "pT4T_NdefMessage" and then processed in the T4T_NDEF_EMU_Next method.
I set mode = Emulation, but when debugging, I found that else if((Answer[0] == 0x00) && (Answer[1] == 0x00)) can never be entered in the ProcessCardMode method, which means that PN7150 cannot get DATA_PACKET, and the code cannot go to T4T_NDEF_EMU_Next. What is the reason for this?
andy_kim
Dear Daniel,
Thanks for your clarification.
Andy
