For the minimum rise and fall time (20+0.1Cb) requirements, does it applies to signal going into the I2C device? Am I right to say it is not critical if the signal is going out of the I2C device?
Rgds
Danz
解決済! 解決策の投稿を見る。
Hi Jozef,
Thanks for your reply.
Hi Dan,
yes, this is correct. The minimum values are critical for the SDA and SCL inputs.
With Best Regards,
Jozef
