Hello @Wenli
Yes, I know you're looking for an I-V relationship, and there's usually a graph of that relationship for a single MOSFET. But for products like UCODE 7 backscatters by switching the reflection coefficient of its antenna between two states in accordance with the data being sent. The logic 1 and 0 of the internal MOD switch comes from the strength of the signal. The default state maximum backscatter is enabled.
Therefore, UCOD presents RF characteristics externally, but does not present the electrical characteristics of the module inside the chip. Therefore, it is more appropriate for your design to focus on the strength of the signal, please understand the inconvenience.
To update this case, you may reply by email.
To provide confidential information or attachments, you may add that online.
Please login to our NXP technical support portal:
https://support.nxp.com/s/case/5002p00002s4HnBAAU
The portal allows access to the full details of the case, including the previous communication.
Kelly
Technical Support
NXP Semiconductor
