Similar to an earlier question, (on MMZ09332BT1) how to calculate bias resistors for 3.6V operation? The datasheet gives some values for 3.3V, but 500 & 90 Ohms are non-standard, so I wondered how critical they were.
I may try interpolating between the values for 3.3V and 5V, but it would be helpful to know what bias currents to set.
Ref: https://www.nxp.com/docs/en/data-sheet/MMZ25332B.pdf?pspll=1
Edwin.
Unfortunately I do not have a guide on-hand for adjustment of bias resistors with Vdd=3.3 or 3.6V. I did however, a guide for adjusting bias resistors with Vdd=5.0V. I hope that is helpful. Please, I sent it to you directly.
Pavel
Hi LPP, can you also send to me? Thanks
Also interested, can you send it to me too?
I am also interested in that, can you send it to me too?
