MCUXpresso always does a clean before building after switching between Debug and Release builds
693件の閲覧回数
rshipman
Contributor V
Why does MCUXpresso always do a clean before building, when switching between Debug and Release builds? I've not changed any settings.
All the temporary files, including object files and the auto-generated make files are kept in separate folders, so why the need to clean? The usual check for dependencies that are out of date should be sufficient.
Info:
MCUXpresso IDE v11.8.1 [Build 1197] [2023-10-27]
Windows 11
RT1021 project
Many thanks.
2 返答(返信)
644件の閲覧回数
ckielstra
My environment doesn't show the cleaning behavior you describe.
Just for sure, could it be that one of your project configurations has the clean option enabled? I think it's on by default, so if you created a new project configuration it might have been enabled.
  • Go to Project / Properties / C/C++ Build
  • Check on top you have selected, Configuration: [All configurations],  or the configurations you want to verify.
  • Select the Behavior tab (easy to overlook)
  • At the bottom of the page, disable the 'Clean' checkbox
679件の閲覧回数
Hello @rshipman
Could you please share your step and log?
I test on my side, change Debug to Release, there is no clean. So I want to refer to your steps to reproduce, thanks.
Alice
