I want to ask whether MC56F84789 support boundary scan test? If yes, where I can get the bsdl file?
Thanks.
Solved! Go to Solution.
I attach the BSDL file, based on the pin counts, there are several files, pls check your part number and select one BSDL file.
Hope it can help you
XiangJun Rong
