I have a specific application where I need to detect the presence (or absence) of a ISO15683 tag at a range of about 10 cm using a Molex 146236-2102 NFC Antenna. Is there an appropriate NXP product?
I appreciate your interest in our products.
Any of our NFC Reader Ics should be able to work with this Antenna. But it is necessary to correctly tune and create a working matching circuit for the IC to decode the RF Transmission properly. Regardless of the NFC Reader you use, each has an Antenna Design Application Note and, this Antenna Design video series will guide you on creating the matching circuit. My suggestion is to please try following all of the video recommendations.
About the distance you would like to achieve, this should not be a big issue since ISO15693 tags are intended to achieve greater distances.
