LS1012A RCW override
Search instead for
ilko
Dear NXP support team,
Do you have a document which describes the JTAG sequence to override the RCW?
I mean the low level JTAG sequence, without CW or some other JTAG tool.
Ilko Iliev
ilko
I need the way to override the RCW source or all RCW words via JTAG in order to implement it in our JTAG Flash Programmer PEEDI: www.ronetix.at
Ilko Iliev
ilko
Nobody from NXP can help with the requested information?
ufedor
There is no requested JTAG sequence.
Please consider using the reset configuration word (RCW) source input, cfg_rcw_src, is multiplexed on
CLK_OUT - POR low level corresponds to the hard-coded RCW option.
