One problem I encountered is LPCXpresso Unable to generate .axf file.
afx file should be generated after a successful build.
Please check if your project can pass build.
Jun Zhang
The situation is that when I build it externally, "make -r all" will appear at the end. I am new to LPCXpresso and I don’t know where the problem occurred.
Ling
Please send us:
1. your chip part number
2. which demo board you are working with
3. problem screenshot
Jun Zhang
