Imx27 vpu codec h264,What is the data?
gale
H264 rbsp or nal data?
I use a rtsp server to send the data,but the palyer can't play.
After  I encode it as soft format mov,player can get it from net and play.I use the same rtsp server.
JTN
I am wondering the same thing. Although the issue I am facing is a bit different. I can decode a stream with mplayer, but not with vpu decoder, even if the exact stream from encoder is passed to decoder.  Decoder just complains that "full picture stream" does not exists.
