I2c reg write in imx_atf code imx93_psci.c
sbmd_1234
Hi NXP Team,
How to access(read and write ) the i2c registers in the imx_atf code ./plat/imx/imx93/imx93_psci.c.
Thanks.
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
You need to add the base address of the desired module that's within the peripheral bridge accessed (AIPS Peripheral Bridge 1).
E.g.
sbmd_1234
I didn't get your point I want to use i2c registers for PMIC please tell me an example or something that will be good for me.
Thanks.
JosephAtNXP
sbmd_1234
One more query here why can't I use this command to put system in low drive mode.
echo 2 > /sys/devices/platform/imx93-lpm/mode
