I2C mux with PCA9543 in linux kernel
3,708 次查看
cyrilgermaine
I'm not sure where I can post this question.
I'm trying to use 2 audio codecs (same ones with same i2c slave addresses) with an PCA9543A, and I don't really know how to do it. So the alsa drivers will switch automatically between the 2 codecs, so they will be seen as 2 different audio cards.
In the init board, I think I have to :
- register the pca954x driver
- register the i2c-mux driver
- relate the pca954x to the i2c-mux and get the 2 created i2c sub-adapters
- and finaly instatiate 2 codec drivers with the i2c adapters
Example:
// Init board code
struct i2c_board_info i2c_info_pca954x[] = {
  I2C_BOARD_INFO("pca954x", 0x70),
i2c_register_board_info(1, i2c_info_pca954x, ARRAY_SIZE(i2c_info_pca954x));
// How to register the i2c-mux driver?
// How to register the 2 codec drivers?
struct i2c_board_info i2c_info_codec[] = {
  I2C_BOARD_INFO("tlv320aic3x", 0x18),
i2c_register_board_info(SUB_ADAPTER_1, i2c_info_codec, ARRAY_SIZE(i2c_info_codec));
i2c_register_board_info(NEW_ADAPTER_2, i2c_info_codec, ARRAY_SIZE(i2c_info_codec));
// Audio SOC code, declaration of the codecs
static struct snd_soc_dai_link davinci_codec1_dai = {
  .name = "TLV320AIC3X",
  .stream_name = "AIC3X",
  .cpu_dai_name = "davinci-mcbsp",
  .codec_dai_name = "tlv320aic3x-hifi",
  .init = aic3x_init,
  .codec_name = "tlv320aic3x-codec.SUB_ADAPTER_1-0018",
  .ops = &ops,
  .platform_name = "davinci-pcm-audio",
static struct snd_soc_dai_link davinci_codec2_dai = {
  .init = aic3x_init,
  .codec_name = "tlv320aic3x-codec.SUB_ADAPTER_2-0018",
  .ops = &ops,
For now, when I register the pca954x driver, the pca954x_probe function is not even called, even if have the "i2c-core: driver [pca954x] registered" log.
Thank you in advance for your help.
标记 (3)
2,710 次查看
cyrilgermaine
Ok for the i2x mux declaration, the i2c board info has to be "pca9543", not "pca954x". Now I have 2 more i2c adapters (#2 and #3), but I stil don't know how to connect my codec driver to them.
static struct i2c_board_info i2c_info_pca9543[] = {
  I2C_BOARD_INFO("pca9543", 0x70),
static struct i2c_board_info i2c_info_tlv320aic3x[] = {
  .platform_data = &i2c_tlv320aic3x_pdata,
i2c_register_board_info(1, i2c_info_pca9543, ARRAY_SIZE(i2c_info_pca9543));
// This doesn't work, it freezes my console before starting Linux
//   i2c_adap = i2c_get_adapter(2);
//   i2c_new_device(i2c_adap, &i2c_info_tlv320aic3x[0]);
//   i2c_adap = i2c_get_adapter(3);
  .init = elips_ol_3io_aic3x_init,
  .codec_name = "tlv320aic3x-codec.2-0018",
  .ops = &elips_ol_3io_ops,
  .codec_name = "tlv320aic3x-codec.3-0018",
2,710 次查看
cyrilgermaine
Done!
Here is how to do it:
static struct pca954x_platform_mode pca9543_mode[] = {
  { .adap_id = 2, },
  { .adap_id = 3, },
static struct pca954x_platform_data pca9543_data = {
  .modes = pca9543_mode,
  .num_modes = ARRAY_SIZE(pca9543_mode),
  .platform_data = &pca9543_data,
i2c_register_board_info(2, i2c_info_tlv320aic3x, ARRAY_SIZE(i2c_info_tlv320aic3x));
i2c_register_board_info(3, i2c_info_tlv320aic3x, ARRAY_SIZE(i2c_info_tlv320aic3x));
