Whether NXP has the tool which can modifiy the rcw about the product of lx2160A
Solved! Go to Solution.
1. You could use QCVS PBL tool to configure RCW.
Please download and install CW_ARMv8_v2020.06_b200629GA_Win_Offline .exe from the following link.
https://drive.google.com/file/d/1Kjq1nLYrtIfWAHYrup5Cf-TTEJI9iWiu/view?usp=sharing
Please download the latest patch release package com.freescale.armv8.11.5.2.GA.Win.updatesite.210130.zip from the following link
https://drive.google.com/file/d/1g4FbibmVuEWQdEhCuaOqMUvs6_xQzzYC/view?usp=sharing
Please open CodeWarrior IDE from C:\Freescale\CW4NET_v2020.06\CW_ARMv8\fsl_eclipse.bat, please install the patch release com.freescale.armv8.11.5.2.GA.Win.updatesite.210130.zip from Help->Install New Software->Add->Archive.
Then create a QCVS PBL project from File->New->QorIQ Configuration Project in CodeWarrior IDE.
2. If your use LSDK, you could run the following command
$ flex-builder -c rcw -m lx2160ardb
Get and modify rcw source code in packages/firmware/rcw/lx2160ardb_rev2/.
Then run the following command to rebuild RCW again.
