I have some questions about PCA9547D.
uzu1111
1,Does the slave side of this IC support many power supplies?
(by way of example ch0->3.3V Bus and ch1->5.0V using?)
2,What should the power supply of this IC select as the material?
3,When I set the power supply of the IC low, is there any limit for connection of the master side and the slave side?
Thank you,
Ehira
guoweisun
For your questions please see below comment:
1: Yes,it supports.
2/3: Please see detail AN262 PAGE14-15 for more detail.
