I have some Questions about PTN3460 External EEPROM
yoonju
I implemented the eDP To LVDS interface on the motherboard using the PTN3460 IC.
After completing the mainboard SMT, I'm testing the PTN3460 interface, I have a some problem.
I uploaded EDID (1280 * 800) .BIN to the PTN3460's External EEPROM. However, EDID data communication through AUX channel is not normal.
As a result, I found that I need to insert the EDID data as well as the configuration data into the EEPROM.
**** Questions!! :
            1) Can I find the TOOL name that I use to create the EEPROM File that combines the EDID + Configuration files?
please.
sleepingshui
Hi, Can you tell me how to generate EDID (1280 * 800) .BIN? Thanks a lot!
guoweisun
Please refer to manual of PTN3460 FoA EDID Updater User’s Manual to set up step by step.
sleepingshui
Thanks! But I am sorry to say I cannot find and download this user's manual in any websites. Can you send these files to me? My email is sleepingshui@163.com. Thank you!
guoweisun
Hi.
I searched your submit same question based on case00203613.
Please following the answer of case00203613.
