How to use fdtput on i.MX Yocto
已解决
跳至解决方案
1,555 次查看
jun_1
I have i.MX 8M Mini EVK which runs Linux 6.6.23_2.0.0.
To configure the SDIO Interface, I run the following command:
fdtput /run/media/boot-mmcblk2p1/imx8mm-evk.dtb /soc@0/bus@30800000/mmc@30b50000 no-1-8-v
However, I got “-sh: fdtput: command not found". I also run “sudo apt-get install device-tree-compile” to install fdtput command, and I got “Building dependency tree... Done E: Unable to locate package fdtput” error.
How can I use fdtput command?
标签 (2)
1 解答
1,459 次查看
yipingwang
The rootfs provided in i.MX Linux SDK 6.6.23_2.0.0 is not Ubuntu rootfs, so the command "sudo apt-get install device-tree-compiler" doesn't work.
You could add "dtc" to rebuild rootfs in Yocto build environment.
I built attached "dtc" binaries file for you, please copy the attached tar ball to your target board directly.
# tar -xzvf image.tar.gz
# cp image/usr/lib/* /usr/lib/
# cp ./image/usr/bin/fdtput /usr/bin/
# fdtput
在原帖中查看解决方案
4 回复数
1,424 次查看
jun_1
Thank you. I successed to execute the command using the above method.
1,529 次查看
yipingwang
Please use the following command.
$ sudo apt-get install device-tree-compiler
1,523 次查看
jun_1
Thank you for your reply.
I tried the following command, and I got “Building dependency tree... Done E: Unable to locate package fdtput” error; it was a copy and paste mistake.
1,460 次查看
yipingwang
# fdtput
