Hi Everyone,
I got a jn5189 board, and in two days, I will get the jn5189 kit for zigbee modules.
I 'll want to set a simple zigbee network use boards form kit(ex: including a coordinator, a router, some end devices ).
The software enviroment was setted(MCUXpresso IDE,JN5189 SDK...),and I used MCUXpresso IDE to creat projects like
jn5189dk6_zigbee_coordinator_bm, jn5189dk6_zigbee_router_bm.Also,I build the .bin files and download them into my board for test.
I know jn5169 zigbee kit includes a Gateway, two board with NFC antenna,because I have used the jn5169 kit to operate the
demonstration(pre-load Zigbee Smart Home Demonstration) .But I do not know the situation(ex : if the jn5189dk6_zigbee_coordinator_bm.bin have to
download into the specific board,like gateway board) of using our .bin files(build from the project of MCUXpresso IDE)to form the zigbee network.
Is JN5189 Zigbee the same concept like JN5169?
Are there any guide(PDF) which can show me how to set the zigbee network of JN5189 kit?(i want to use the .bin fles created by MCUXpresso IDE )
if you know, please feel free and contact me,thank you!
Hi Ricardo,
Is there any document of guide for getting started of jn5189? I got my jn5189 kit, but i don have document to help me set up .
for example, i don know how to power on my board
[Carrier Board (OM15076) with NFC Controller Board (OM5578)],
is there any guide document for zigbee setting of jn5189?(like "JN516x-EK004 Evaluation Kit User Guide" for jn5169)
Thank you!
Could you check these documents? JN5189DK Getting Started and JN5189-DK006 Development Kit User's Guide.
And also the documentation available in the SDK, located in the same path: SDK_2_6_4_JN5189DK6_doc.zip\docs\wireless\Zigbee
Ricardo
Hope you are doing well. Could you please check the "ZigBee Demo Applications User's Guide.pdf" (Path: SDK_2_6_4_JN5189DK6_doc.zip\docs\wireless\Zigbee).
There you can find the functionality description of each device (Coordinator, Router and End Device).
Hope this helps.
Ricardo
