How to jump to new program in MC9S12XEP100 chip?
TingTing
Hi Developer,
I want to jump new program from bootloader.
bootloader address: [0xC800,0xDFFF]
new program address:[0xE000,0xFC00]
I used code as followed:
asm call 0xE000,0x00;
Then I run bootloader step by step. It can run into the line 'asm call 0xE000,0x00;',but the new program had not been called.
Need your help to solve it.
Thank you.
BR, Shi Ting Ting
lama
I am sorry but there could be anything hidden and not expressed in your description.
I would like to show you the solution.
Have you seen
file:///C:/Users/nxa14252/AppData/Local/Temp/1/AN4258.pdf
and it SW files which provide solution...
You can also search a community for troubles solved with this AN.
http://www.nxp.com/files/microcontrollers/doc/app_note/AN4258SW.zip
(not related info: https://community.nxp.com/t5/S12-MagniV-Microcontrollers/List-of-MagniV-S12-X-Application-notes/ta-p... )
Ladislav
