Can someone please help me and tell me how can I create an S-record file? I am new with embedded systems. I am using mpc5121e processor and trying to turn on the leds on the ads5121 board. The only connection I have is a serial modem and an ethernet cable. I have been told that I need to load my C code via u-boot using the loads command. How to create the s record file and how to load it? thank you very much.
Hello
I assume you are using CodeWarrior for your development. Am I right?
If this is the case you need to check the box "Generate S Record File" in the "EPPC Linker" Panel.
CrasyCat
