How to config SJA1105?
2,568 次查看
xijin
Hi All,
My board is LS1021ATSN. I am running the TSN demo described in Open Industrial Linux User Guide (OpenIL_UG.pdf). I have some questions about how to config sja1105.
1. Sja1105-tool provides four *.sh files to generate configuration files. But these *.sh files only focus on the demo. If I want to perform other configurations, what should I do? Do I have to modify the XML file manually?
2. SJA1105 supports the time-aware scheduler. Time slots can be grouped together to form at most 8 cycles. But the demo does not explain how to config multiple cycles. I have read the software user manual for SJA1105TEL (UM10944.pdf). But I am still very confused.  Except for OpenIL_UG.pdf and UM10944.pdf, are there other documents about SJA1105?
标记 (1)
1,377 次查看
972515089
你好,,我也在用这块板子,不知道你的问题解决了没有?
