Kx:FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
RndA: CFC10C4F63053E150825C8C7E805F302
RndB: AF87144689F30FCA69DE085CEA979CBD
TI: 340CF9A0
Session key base KMAC: 229B02926FBF89F30FCA6963053E1508
KMAC: F7636FC79CA67221BADCF2C04506F195
I want to send ReadPlainMAC_MACed at SL3 reads sector data,
The command sent should be 33 0000 01. How should I calculate the Mac? I refer to the ds522333 document 。
As you might know, there are some of the documents and libraries which are under NDA (Non-Disclosure Agreement) and placed in docstore, could you please follow these guides?
Docstore tutorial part 1: User Registration|NXP : https://www.nxp.com/video/docstore-tutorial-part-1-user-registration:DOCSTORE-USER-REGISTRATION
Docstore tutorial part 2: portal usage|NXP :
https://www.nxp.com/video/docstore-tutorial-part-2-portal-usage:DOCSTORE-TUTORIAL-PORTAL-USAGE
Also, you will need to contact one of our distributors available in the Distributor Network|NXP to help you through the NDA process.
https://www.nxp.com/support/sample-buy/distributor-network:DISTRIBUTORS
