I install Platform_Software_Integration_S32R45_2022_03.exe, and import "Bootloader_S32R45_ASR_4.4_M7" project to EB.
Then, i add "Platform" module to the project, and generate project.
But, "Platform" module is not included in Modules.mak file.
How to configure it and make it ok?
Hi @aiweixin ,
If you added modules in EB Tresos, it needed to manually change Modules.mak to add Platform module into module list.
EB Tresos only generate code based on your configuration module, it cannot change Modules.mak.
