How Can I Write S32S247TV to Flash Memory
jsanta
I tried to write to Flash Memory of S32S247TV
But S32S247TV SDK is not supported "Debug_Flash"
so, I tried this.
- made a "Debug_Flash" Build Configuration.
- made a "Debug_Flash" Debug Configuration, using "S32 Debugger"
- made a "Debug_Flash" Debug Configuration, using "S32 Debugger Flash Programmer"
What can i do to fix the problem?
jsanta
Solved! Thanks!
