Getting started for the RT1060 WiFi module is different from the latest SDK Example
343件の閲覧回数
AKobamasa
The explanation for Getting started for the RT1060 WiFi module is different from the latest SDK Example.
I am trying to get WiFi to work with the help of Getting Started with the MIMXRT1060-EVK, but the file structure included in the WiFi example project installed in the IDE using the import SDK example has changed significantly. There is no app_config.h and I can't find the file defining the WiFi module to use. Is there another SDK file?
6 返答(返信)
227件の閲覧回数
AKobamasa
Hello shaun_wu,
Thank you for responding to my question.
I am not sure how to get that settings window. Could you let me know about it?
Best Regards
323件の閲覧回数
AKobamasa
I have an additional information for this question. I use MCUXpresso IDE v25.6.136 and have got this issue.
I check this with IDE v24.12.148 and can see the file app_config.h in the directory 'source'. So I guess this is a bug in v25.
207件の閲覧回数
shaun_wu
Hello @AKobamasa
You could refer to following image:
Best Regards
Shaun
291件の閲覧回数
shaun_wu
Hello @AKobamasa
new sdk is different as older version, you could refer to following guide: Examples — MCUXpresso SDK Documentation
Best Regards
Shaun
288件の閲覧回数
shaun_wu
Hello @AKobamasa
You could find it in marco definition of project:
Best Regards
Shaun
148件の閲覧回数
AKobamasa
Hello shaun_wu
I succeeded to build and run the project with this setting in MCUXpresso v25.
Thanks a lot.
