I'm using Freescale Test Tool 11.3.0 with an Evaluation kit mc13224.
I'm using Beestack codebase.
Using Beekit I have enabled the OTA server (on the coordinator) and the OTA client (on the other device, router)
I've tried to use the "OTA Update" supplied by Test Tool, with a *.bin file generated by IAR 6.10.
The update starts, the server send the update,
but I receive an Abort message, and the client resets itself.
(I can see these steps through the "Message Log" displayed in the OTA Update window)
Is "OTA Update" working with Beestack codebase?
Someone could help me?
Solved! Go to Solution.
Hi martinhp,
First of all: thank you for your answer.
I'm using codebase 3.0.11, with IAR 6.10, and Beekit.
The OTA Update works, I was using a wrong configuration, for the OTA client. The main problem is the lack of a manual for this interesting functionality.
Do you know a good documentation for this functionality?
What code code base are you using? 3.0.11?
The latest codebase is for the IAR 5.50 not for the 6.10.. try with this. may be this is causing the problem.
Martin
Hi martinhp,
