When no input signal is added to the active second-order band-pass filter, there is always a signal at the output, and the output signal frequency follows the cut-off frequency of the filter. The output signal amplitude is very small (tens of uV peak-to-peak value). Due to the measurement of weak signals, the noise of tens of uV is very annoying, and I don't know how to remove it.
