I am looking for a solution for fast firmware (BIN file) uploads to PCBs with KL25 IC.
The PCBs have a connector for SWD programming (with SWDIO, SWCLK and RST).
For each production, we have to upload the firmware to around 1000 pcs.
I read a few posts about that (like: https://community.nxp.com/t5/Kinetis-Design-Studio/How-to-upload-firmware-without-starting-the-debug...), but they are a bit old, this is why i am asking again the question.
Could you please point me to a recent solution for mass production firmware uploading for PCBs with KL25 IC ?
Solved! Go to Solution.
Hi @offin
I hope you are doing well,
To program by SWD small production runs you can take a look at the MCUXpresso GUI Flash tool. Please , check the chapter 14. The GUI Flash Tool from the MCUXpresso IDE user guide.
If you do not want to use a IDE to program your KL25s , you can take a look at the Erich Styger's reply in this thread Programming a microcontroller without IDE.
I hope this could help you, let me know if you have more questions.
Diego.
___________________________________________________________________________________
Do not forget to mark a reply with ACCEPT AS SOLUTION , if solves your inquiry.
We are not following threads after 7 weeks.
Hi @offin
Diego.
Hello Diego,
Thank you for these links.
The Erich Styger's tutorial "Standalone and Command Line Programmer with MCUXpresso" is perfect.
The solution of executing a BAT file for each program action works fine, and it meets my needs.
My problem is fixed.
Thank you again !
