What is the orderable PN for the TJA1100 Evaluation Board? My customer is hoping to use this as an alternate to the BCM89500.
Thank you,
Adam
Solved! Go to Solution.
Hi Adam,
The orderable PN for the TJA1100 Evaluation Board is OM14500/TJA1100. In order to obtain this board, please contact your Account Manager.
Tomas
Is there documentation for NXP SJA1105 Ethernet Switch register definition/control available? If so, how can I obtain it?
Are there drivers/libraries for the SJA1105? Is there a recommended MCU to use with the SJA1105 which already has drivers available?
Hi Adam,
Tomas
