EB tresos config S32K312
shiqi_seventeen
Hello Team
When I used EB Studio to config S32K312's GPIO ,there is a question:" This ECUC must be defined in OS",what means about this?And How can I to solve it?
Thank you
CongDang
PortEcucPartitionRef is configured for multicore feature. If you use single-core, the PortEcucPartitionRef should not be configured.
I also got the info on S32K3:
So, you need to remove the element on PortEcucPartitionRef for S32K312
