Does J-Flash can program 512kb in kw38
jingfang
KW38 is 256kb program flash + 256kb flexnvm.
When use J-Flash erase show : selected data does not fit into selected flash sectors.
How should I slove it?
EduardoZamora
I apologize for the inconvenience this might cause you, could you please contact SEGGER for more information about this inquiry?
Eduardo.
EduardoZamora
Hello @jingfang,
Hope you are doing well.
Just to confirm, are you using a custom board or is it a FRDM board?
Are you trying to perform an Erase Sector or is it Erase Chip (Manual programming)? Does this error occur if you try to program a binary file?
By any chance, have you modified the Flash setting? Could you please share a screenshot of your Flash settings (Options tab > Project Settings… > Flash)?
Please consider doing some tests with J-Flash Lite and JLink Commander (Jlink.exe), just to confirm the behavior that your application presents. You can find the corresponding User Manuals inside SEGGER > JLink > Doc > Manuals.
Eduardo.
jingfang
I test J-Flash V7.70 with demo board KW38,the problem points remain.(IDE GUI FLASH TOOL is OK).
J-Flash set as follows:
The bin file size is 520KB.
EduardoZamora
Just to confirm, what is the programmer/debug probe you are using (for example JLink base, JLink Pro, JLink Plus...)? I am still trying to reproduce this scenario on my side.
Could you please try flashing a binary file with a smaller size? Please consider doing a mass erase to the flash memory using the GUI Flash Tool before programming. After this, try to flash a smaller binary.
Eduardo.
jingfang
small size bin is ok,I split the 512KB bin into 256+256KB,it is ok.
Jlink as follows:
EduardoZamora
Does this mean that you found a workaround and the problem is now solved? Could you please confirm this?
Eduardo.
jingfang
I found a solution, but this one requires splitting the bin file.
I wonder, is there a way to do this without splitting the bin file?
EduardoZamora
Eduardo.
