Does FS6503 can support only rising edge wake up?
Customer want only rising edge , not want high level,
Whether there is a register that can set the rising edge to be valid?
Solved! Go to Solution.
Hi Jingfang,
By setting WU_IOx_1:0 bits to 0b01 it is only possible to select a wake-up on rising edge or high level.
Tomas
Hi Jingfang,
Tomas
