Difference between TJA1021T/20 and TJA1021BT
1,315 次查看
ts76
What is the difference between TJA1021T/20 and TJA1021BT?
标记 (3)
1,307 次查看
TomasVaverka
Hi Tomasz,
The TJA1021BT is based on our latest SOI3+ process. Below you can see the changes and benefits of this process. The TJA1021BT  is a drop-in replacement for TJA1021T/20, meaning it is pin-to-pin and HW/SW compatible.
Tomas
1,303 次查看
ts76
Thank you very much.
