Hi I am testing ctimer0 of the RW612 using the example from zephyr https://github.com/zephyrproject-rtos/zephyr/blob/main/samples/drivers/counter/alarm/README.rst I see the max frequency it is running at is 16MHz. Any possible reason why I can't generate interrupts less than 8 us.
Could you please share with me some steps to replicate this behavior?
Daniel.
Let me check this.
